Deer30
Hi, my dishwasher is leaking water from the baffels. So, I called your company and ordered 2 new baffels. They came today and I put them in and now it does not leak on the left side, but continues to leak from the right side. Also, I notice that the water seems to come out higher than where the baffel is. Like from the inside about where the dial is, only from the inside about four inches from the top of the dishwasher. And still leaks from the new baffel on the right side. Help, please. Thanks, Carol
Also, what is the life expectancy of a dishwasher. We use it a lot, especially during canning season. Mine is almost seven years old.
Carol,
Remove the screw holding the float dome (#302 on the diagram) and remove the float dome. Pull up the float (#305) and clean the float. The float should freely move up and down.
Here are the breakdown diagrams and Replacement parts for GE GSD2200G00WW | AppliancePartsPros.com
