Debris in Strainer and Standing Water
HELP - We have standing water at the base of the spray arm and loads of debris in the strainer. I am having no luck removing the spray arm or strainer. Our dishes, particularly the top rack, are drying with filth. Please help. TIA
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
Sorry cannot find any info with given Model Number
Perhaps this will be of some use
http://www.applianceaid.com/dishwash.html
Sorry, could you try Model # GSD4020202BB
Serial # VT769229B
Thanks Again
Tried Model GSD4020Z and see you probably have a jammed drain solenoid. Part AP2039683
[quote=denman;48692]Sorry cannot find any info with given Model Number
http://www.applianceaid.com/dishwash.html[/quote]
Can you tell me how to make that repair? Thanks
Remove your kick panel under the door, the drain solenoid is attached to the motor. With a little skill, you can replace it without pulling out the dishwasher.
