I was replacing a lightbulb in the under hood and a small spark killed the entire unit. I know it is a fuse or something like that but where? I looked behind the keypad but cant see anything obvious. I tried to remove the unit from the wall but cant get the back of it off the wall. Apparently there are pins that snap into place when it was installed so I dont know how to unsnap to get it off the wall. Worse, I am not sure it needs to be removed at all, but it probably does. HELP!!! My wife is going to kill me!
its under the clock buttons, now which one is the fuse?
Below is a link to a video that shows you what the fuses look like and how to test them if they are bad. The located of the parts may vary slightly on your model, but the test is the same.
Microwave No Power Repair : ApplianceRepairLesson.com
Good luck
