Dead Kitchenaid dishwasher
When I push the start button, the rinse only light flashes. Nothing else happens. Push cancel and the cancel light flashes, but nothing else happens.
I removed all the wires on the control paanel and reattached them and it worked for one cycle but is now dead again.
Hi David,
Most likely the problem is a stuck one or more pad(s) on the key pad which is a part of the control panel.
In order to provide the right part number I need the color of it.
Here are the break down diagrams for the Kitchen Aid dishwasher Model KUDI01TJBL0
This is from the tech sheet.
[FONT=Swiss721BT-Bold][SIZE=1][FONT=Swiss721BT-Bold][SIZE=1][LEFT]STUCK KEY: [/SIZE][/FONT][/SIZE][/FONT][FONT=Swiss721BT-Roman][SIZE=1][FONT=Swiss721BT-Roman][SIZE=1]If the control detects that a key is stuck in the depressed position,
dishwasher operation will be suspended and the control will flash the
light for that key until the condition is corrected. If a key without a light is
stuck or multiple keys are stuck, the control will flash the light for the Rinse[/LEFT]
Only/Quick Rinse key.
