Brand: GE Appliances
Model Number: GDF570SGJ2CC
Main Symptom: Dead, no indicator lights at all. Buttons do nothing. Serial #GL823316B
Error Code (if any): None
Parts or tests already tried: GE Service reprogrammed one of the logic boards using a connector at the bottom. He only needed to remove the valance and insulation. It ran correctly. I tried it use a few weeks later, and again it was dead, no lights, no buttons. I figure it’s one of the logic boards, but there are two, a large one and a small one. I can replace parts myself, and I have a professional VOM and know how to use it, if you know of a way to test them. What can you suggest, and which parts should I buy?
