Dc97-20036b need an installation video for this part
Brand:samsung flex
Model Number:
Main Symptom:saying top load door is open when closed
Unfortunately, we do not have a repair video for this part. If you could share the model number of your appliance, I would likely be able to provide some step by step instructions for replacing this part.
model number for the washer is wv60a9900av
There should be two screws at the back of the top panel that would need to be removed after unplugging the power cord. Once removed, the top panel and lid should lift up and out from the back. From there, use a flat head screwdriver to remove the detergent cover and cups. Remove the three screws securing the console, pull the console forward and disconnect it. Remove the detergent cups at the front with a flat head screwdriver and disconnect the hoses. The top lid cover should lift up from the front (may need to remove a couple of screws) and then it can be set to the side. This should give enough clearance to disengage the locking tabs and remove any screws securing the top tub cover to the tub.
ok thanks omw to try it out
