Darrell
I get the F2 Fault code, and the SUDS code also during the rinse/spin cycle, and the water won’t drain. The pump makes a clicking sound. I cleaned the trap out, and I even took the pump off, and took it apart. I didn’t see any broken wires on the windings. I also cleaned the drain hose out. It seems when the drain hose is directed into the drain it wont drain, but if I leave the drain hose down to drain into a bucket it will work better, but the pump still makes a clicking sound. I would like to know if I need to replace the pump, or will the pressure switch cause the pump to click, and not drain. Thanks for your response.
With these machines it could be a number of things, but I think replacing the pump is your best bet.
