Dacor oven clock
clock is blinking, press the button to set it,and nothing happens. All the other buttons on the board work. Tried turning it off at the breaker. left it off for several hours. Still won’t set.
A model number may help others help you.
Some units use a keypad and a control board. The problem could be on either part.
On other units the keypad is part of the control board so in this case the control board is the probable cause.
[quote=denman;754312]A model number may help others help you.
On other units the keypad is part of the control board so in this case the control board is the probable cause.[/quote]
IT IS EPICURE ECD230
I could not find any info on this unit at AppliancePartsPros.
I did find it on the Sears parts site.
Looks like it has a keypad and a control board.
I cannot find any technical info on it so have no way of testing the keys to see which part is bad.
I have this same problem. Press the clock button and does not work/beep. Does anyone know how to fix this problem?
