[COLOR=#333333]After a power surge the Dacor oven will not heat to temperature.[/COLOR]
[COLOR=#333333]The oven button is selected then the temperature increase button is selected which shows the standard 350 degrees, after a minute it then reads pre-heat at 135 but does not heat up. Also it will not heat up on broil or convection. I turned the electric breaker off-on as well as depressing the high temperature relay reset behind the door latch without any success.[/COLOR]
[COLOR=#333333]Any suggestions.[/COLOR]
[COLOR=#333333]Wayne[/COLOR]
Wayne, I’m having the same issue, did you find a solution?
Vic
