Dacor double ovens
Two Questions:
  1. my Dacor CPS230 double electric, single convection ovens were both in use last night when they shut off (on their own) and the display board displayed “OFF” for both ovens. I turned the circuit breaker off, waited 30 seconds and turned breaker back on and both ovens worked again …for about 3 minutes. Do I need new circuit breakers or is this an oven problem?
  2. I have been having difficulty removing the lens cover from oven to replace light bulb. I have tried to loosen by hand but the lens cover won’t budge. I have sprayed a liquid degreaser at lens but that doesn’t appear to help. (The oven is very clean, not greasy).
    thanks Anne
Was it flashing? Did you have to reset the clock?
