I have a Kenmore Ultra Wash model 665 Ser.#15769000 that won’t run. The cycle buttons light up, but the start button does not. Can I determine what the problem is? Thanks for any help.
The 665 tells us that the unit was made by Whirlpool but there should be about 8 digits after it which is specific model info.
Not sure if the Serial Number you show are the rest of the model number, please check it.
[quote=denman;463950]The 665 tells us that the unit was made by Whirlpool but there should be about 8 digits after it which is specific model info.
Not sure if the Serial Number you show are the rest of the model number, please check it.[/quote]
[FONT=Arial][/FONT]
KENMORE MOTOR 6.0 amps 0
Model 665. 15769000 60Hz 120 Volts 9
Serial FL5024041 11.5 Total amps 0
Stock no. 15769 E71195 2
Type 280-1 2
Replacement parts for KENMORE 66515769000 | AppliancePartsPros.com
The Sears parts site should have a parts breakdown.
Sounds like a control panel (keypad) or a control board problem.
As you can see in the tech sheet a number of keys share common lines so if a certain set of keys do not work then that is where your problem is.
This still does not narrow it down enough so the usual way to troubleshoot is to check the keypad with a meter, if it checks out OK then replace the control board.
Still a bit of a crap shoot but your odds are better.
Also you may want to try the following.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
15769000.pdf (172.5 KB)
