Crosley Elec. Oven
My oven part will only heat to 195 degrees no matter how high you set the temp… ( and it takes forever to get to 195 )…stove part works fine…any suggestions???
If you can’t see the bake element get red hot then I would check the bake element for continuity with a ohm meter.
