Brand:LG
Model Number:lrfxs2513s?00
Main Symptom:Craft Ice maker not working in Freezer
What happens & when: Replaced water valve assembly after speaking with Rep. Installed, flushed water in upper water supply, icemaker in door works fine. Turned on freezer Icemaker, temp set to -2, hit the reset, ran itls cycle, no water, l4ft for 48 hours, no ice. If I perform the reset should I get water in the ice tray?
Parts or tests already tried:As noted replaced water supply valve, double valve, one for top and one for bottom.
Since the top icemaker works normally, water supply/filter pressure to the refrigerator is probably okay. And because the Craft Ice maker completes the test/harvest cycle but gets no water, I would not replace the Craft Ice maker yet.
Next diagnosis:
- Run Craft Ice test mode again and listen at the valves during the fill portion. The Craft circuit requires both the pilot valve and Craft Ice secondary valve to energize for water to reach the mold.
- Check water directly out of the Craft valve. Disconnect the Craft outlet tube at the valve, direct it into a container, then run the test.
- Water comes out: valve/control are working → suspect a frozen Craft Ice water line/fill tube.
- No water: electrically test the valve circuit.
- LG service information gives approximately 24–26.5 Ω for the Craft valve and 69–76 Ω for the pilot valve, measured through the circuit from the PCB. If resistance is good but the valve isn’t being powered during test mode, check for approximately 24 VDC output from the main PCB during the fill command.
- If water leaves the valve but never reaches the Craft maker, check the water-pipe/fill-tube heater circuit and inspect for a frozen line. LG’s troubleshooting specifically points to the heated water-line circuit in this situation.
Most likely based on what you’ve already done: frozen Craft Ice fill line / water-pipe heater issue, followed by a wiring/PCB issue. The fact that it cycles correctly after reset tells us the Craft maker is at least receiving power and able to perform its mechanical test.
Also, 48 hours isn’t the issue here if you’re watching the test cycle complete without an actual water fill. The normal 48-hour Craft Ice waiting period applies to production after installation/startup.
I’d do the “tube off the Craft valve + test mode” check next. That will split this quickly between frozen line/heater and electrical valve-control.
