Cracked Outer Glass
Safe To Use Washer W/ Outer Glass Crack?
What Actual Purpose Does This Glass Serve?
Is ‘fix’ Difficult?
Thx, Joel
As long as it is not leaking and you can live with the crack you will be fine. If you are mechanical inclined then it is not that bad to change. The outer glass is there for looks, it serves no other purpose.
