The Hamilton Beach counter top Convection oven Model # 31197 is hardly 2 months old and convection fan stopped running. Everything else is working OK. Apprecitate an early reply. Thank you.
If you can. Try to check the wires going for the fan. I had a one of those although a different brand and one of the wires burned into repaired that and moved the wires a bit and never had another problem.
Hope that helps
nat
