Hey there! Based on what you’re describing with your LG washer, model WM3670HWA, I suspect the problem is with the cycle selector knob’s rotary encoder or the display control board.
The fact that the knob still clicks when you turn it, but the selected cycle only changes intermittently, is a good clue. The mechanical clicking doesn’t necessarily mean the electrical contacts inside the selector are working correctly.
The display control board may need to be replaced, but I’d recommend checking a couple of things before ordering it.
Here’s what I’d check first
1. Reset the washer. Unplug it for about 5 minutes. With it unplugged, press and hold Start/Pause for 5 seconds. Restore power and try selecting different cycles.
2. Check the selector knob. Pull the knob straight off, if it is the removable type, and inspect it for cracks or damage. Make sure it isn’t slipping on the selector shaft. If the shaft turns normally but the display skips or ignores selections, the problem is more likely electrical.
3. Check the control board connections. Unplug the washer before opening the control console. Inspect the wiring connectors for loose connections, corrosion, or moisture damage. Reseat any accessible connectors and test the selector again.
4. Watch how the selector responds. Slowly turn the knob one click at a time in both directions. If the display skips cycles, moves backward unexpectedly, or fails to respond to some clicks, that strongly suggests a failing rotary encoder or its associated circuitry.
Recommended replacement part
For your model, the display control board is the most likely repair if the knob and connections check out.
LG Washer Display Control Board EBR78534427 — AppliancePartsPros part AP6041581.
Genuine OEM Part+1
You can view the part here: LG Display Control Board EBR78534427.
There are different display board listings associated with the WM3670HWA family, so confirm the full model suffix before ordering.
One quick question: When you turn the selector knob and the cycle doesn’t change, do all the other buttons, such as Wash Temp, Spin Speed, and Soil Level, respond normally?
If they do, that would further support a problem with the selector encoder or display board rather than the washer’s main control board.
