Cooling On /Off Button starts compressor and then immediately compressor turns off
Brand: Kitchen Aid
Model Number: KBFC42FTS03
Main Symptom: Compressor will not stay on. Turns off after 2 seconds
What happens & when: When turning the Cooling button to “On”. the compressor starts and then shuts off after 2 seconds. Light in lower drawer turns on with compressor and turns off when Compressor turns off (2 seconds). Panel in the refrigerator turns on and then goes dark when compressor turns off.
Error Code (if any): None
This is a common problem with an expensive solution. You will need this kit, W10802701 Electronic Control Board | Genuine Whirlpool OEM In Stock
Can I do it myself? Saw a video and it did not look complicated. any special tools needed? Repalcement fridge is $10K.
Also, Service tech who came and looked at it this afternoon gave me a different part number. WPW10468946. Do you confirm your part number / link?
I wasn’t there to see what he looked at. I know what the symptoms are that you described, and that the kit I recommended has worked to fix the problem you have described. I cannot guarantee the part he mentioned will fix the problem.
