cooling fan not coming at times
front panel gets very hot and the cooling fan does not come on at times. replaced the fan twice already, cleaned out all the dust. We let the refrigerator cool down and then it works for a while. It appears to be happening more so on hot days. Also for a couple times the refrigerator doors have been left open for a long time, could that have doen some damage.
Look at my response below “Kitchenaid refrigerator hot door frame”.
Which control board are you refering to, the one on the top in the refrigerator compartment or the one on the bottom by the compressor?
there is also one that is called an inverter, I am assuming that is for the icemaker. Since yesterday it has been working ok.
The inverter board powers the compressor, the one by the compressor with a cover controls the condensing fan motor. It’s probably your problem.
