Cooktop on light will not go off when one particular burner is turned off
Brand:Whirlpool
Model Number:WCC31430AB02
Main Symptom:
This is going to be a failure with the infinite switch and this can be verified by testing each switch for continuity with the power supply to the appliance being off. On each switch, terminal L1 can be tested for continuity to terminal P when the switch is off and the P wire disconnected. If there is continuity that switch has failed. Here are the switches used with this model.
Left front and right rear switch- WP7403P238-60 Infinite Switch Top Burner Control Switch | Genuine Whirlpool OEM In Stock
Right front and left rear switch- WP7403P239-60 Infinite Switch Top Burner Control Switch | Genuine Whirlpool OEM In Stock
