Cooktop always sparking
I have replaced the spark switches and the spark module. the burners continue to spark after the burner has a flame. if you turn the knobs all the way to the low, the burners are still sparking. i have inspected the wires internally and they all look good. what am i missing. it seems that it is something easy but i’m missing it. any help would be great.
thanks :mad:
What is the complete model number of the unit?
here is the model # I’m working on [FONT=Arial][COLOR=#000000]pgt136ud[/COLOR][/FONT]
do you have any ideas.
The problem can be a bad or just greasy burner igniter (electrode). This stove has a re ignition system and is very sensitive to igniters condition. You can learn more about such system from one of our precious posts: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/11513-viking-range-professional.html
Hopefully just a good cleaning will solve this problem.
Thanks Gene, it is very dirty with left over grease, what do you recommend cleaning with? hot water and soap? would you use a old toothbrush or iron bruch.
Try to use isopropyl alcohol and a tooth brush.
gene
just a question, why would the diry dried grease cause the ignitors to continue to spark. I don’t understand why that would cause it. what would you recommend would need cleaning. i replaced all the spark switches. please advise
thanks
eduardo
Eduard,
Please click on the link in the previous reply and read that article.
