Control vs computer
after a multitude of problems with this $2500 piece of junk it is now completely malfunctional. When attempting to use the appliance many of the touch controls are non-responsive. the display lights up but the keypad only works on about half the characters.
The first time this happened the display prompted me to remove the oven probe, which was not in (and had broke after about 10 uses).
Anyways i powered the unit down, and then re-powered it which seemed to clear the problem.
Now the unit powers up but the keypad has only limited use.
Any idea whether this is the control pad…part # W10206070 or the computer part #8507P232-60.
Seems relatively easy to replace the part, I’m just not sure which one to order
Parts for Jenn-Air JDS9860BDB Range - AppliancePartsPros.com
See the attachment for the wiring diagram
Below is a manual that should help.
You will have to join the site and be logged in to be able to download it.
http://appliancejunk.com/forums/index.php?action=downloads;sa=downfile&id=438;t=1411635770
The usual way to troubleshoot these problems is to check the control panel/keypad with a meter.
If it checks OK then replace the control board.
Still a bit of a crap shoot but your odds are better.
You may also want to try the below.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector. Use electronics contact cleaner or isopropyl alcohol.
JDS9860.pdf (104.4 KB)
