I have to replace the control board and fuze.How hard is it to do? Is there A break down on this model avalible to look at to see how to take it apart? Thank you for you help!![]()
Here is a parts breakdown
Replacement parts for WHIRLPOOL DU1145XTPB6 | AppliancePartsPros.com
Here is the tech sheet
https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208535451.pdf
Not a hard job just take your time.
