Control Panel
No error codes, sometimes the buttons on the control panel does not respond when pressed…still they will work with repeated efforts:( …but it is getting very annoying. What could be the cause?:confused: All connections seem to be good…
Just replaced the hub bearing assembly which corrected the bearing noise issue, now if I can just get the thing to startup when I want it to, I’ll be happy.:slight_smile:
I am guessing the interface or the control unit. For some reason those parts do not come up on the parts diagram, so talk with APP and see what they can tell you about availability and cost.
