Hey there folks,
I have a Whirlpool Calypso washer and the other day the touch pad of the control panel decided to stop working i.e., pressing any button doesn’t light up the option chosen.
First I checked the breakers … they were fine.
Then I pulled out the volt meter and checked the outlet … that gave power.
Then I opened the back of the control panel and tested the voltage going into the Machine Control Board … that had 120V as well!
So I followed the lines going from the Machine Control Board to the Motor Control Board and expected it to get 120V as well, but that wasn’t the case … thus my rookie answer was that the Machine Control Board must have a broken electronic part on it so it’s not forwarding power to the Motor Control Board (based on my results, I was probably wrong).
Hence I bought a new Machine Control Board and just replaced it expecting (/hoping) for the machine to work … DOH! no dice, it still doesn’t work.
Now I hope to gain some experience from you experts out there on what I should do next?
Here’s the diagram page for my machine:
Model GVW9959KQ2
I didn’t happen to notice an in-line fuse, and the lid switch being open or closed doesn’t have an effect on the dryer, thus I assume it wouldn’t have one on the washer either.
Please help
Laundry for 5 is piling up.
Thanks in advance,
Roger
