Hi, could anyone please tell me if it would be possible to substitute the control panel on a Kitchen Aid dishwasher model KUDS01IJWH1 for the control panel of a Kitchen Aid KUDS01ILBT3. Will the control panel of a KUDS01ILBT3 work on the KUDS01IJWH1. I live outside the US and the control panel of my KUDS01IJWH1 is not working and the only control panel I’ve been able to find is a KUDS01ILBT3. Will it work? Thank You
If I look up both model numbers on AppliancePartsPros the control boards are the same AP3775506 (8564543) so they should be the same.
As long as you are sure that it is a control board problem then you should be OK.
Note that the board is fused and also control panel problems can look like control board problems.
denman, thank you so much for your help.
