Control Panel Removal
I need to replace the plastic control housing and must take off the plastic control cover to do so. How does the control panel come off? How do I remove it (is it screwed, snapped, etc). No screws are evident, but may be hidden?
Hi PeteME
I’m assuming you already removed the fascia panel .
Remove one screw on each side of the inner door panel holding the controls bracket and pull it out as far as wires go. The housing for the control module has three tabs on the bottom. Push them up and in and push the housing inward.
Now you can replace the housing.
Good luck.
