Kitchenaid Diswasher KUDS01ILBS6 – the displace shows two dashes; also “Add a Dish” light on; press “cancell”, the water is draining. Otherwise, nothing is working. what is likely the problem ?
Hi.
The problem could be bad door switches, bad connection to the pin 8 at the control board, control panel, control board.
For the detailed tests open the toe panel and locate the instructions in the back of it.
Thank you.
Simon.
