Brand: Jennair
Model Number:JDS1750EP0
Main Symptom: Error code: F2E0
What happens & when: tha above error code showed up 1st few times. The display shows the time, nothing else. None of the keys are working, therefore the oven does not operate. No controls working. I reset the system multiple times ( by powering off)
Error Code (if any): F2E0
Parts or tests already tried: I opened and took out the control Panel. All cable connections look ok. The ribbon cable looks good. Any suggestions? Will replacing the control panel help. Where can I find instructions to replace the control panel.
Here’s the service manual for that one, that should go over what you’re looking for. The repair/disassembly section starts at page 4-1.
service-manual-w11174814-revb.pdf (9.8 MB)
Thanks! I appreciate your advice. I just ordered the Control Panel and the Ribbon cable (although the cable is not looking damaged). The manual that you sent is not for my model. Would you know where to get the repair manual for Jenn-Air JDS1750EP0 or similar. Thanks again.
That is the service manual for your model, it covers multiple models, some of them have consoles at the front like yours and others at the rear. The access information you are needing starts on 4-2.
