HELP-THE control panel locked on my Whirlpool Duet HT-How do I unlock it.
See if unplugging the machine and leaving it sit for a short while will free things up. Then look inside the top for the tech notes which should show you how to put the machine into test/diagnosis mode so you can see if there is still a problem.
Te following may help
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208181790.pdf
Note always a good idea to use the actual sheets that came with the unit as there may be some variations.
I tried unplugging it -that didn’t work- I’m not sure what yuo mean by “look inside the top” I took off the top front and there is just a circuit board. I read in a manual(not Mine)that when the control lock is on it should still start. None of the buttons are functioning. Thanks for any help.
Inside the top should have been a copy of the tech sheet, the same or similar to the one Denman referenced.
Here is a service manual for an earlier version of your machine which should give you additional information. Check to see if you have power getting to the control board, and if so and you cannot get the machine into test mode you may have to replace it on speculation that replacement will solve the problem.
Here is the operators manual as it sounds like yoy do not have one.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208182042.pdf
[quote=sidfink43;158714]Inside the top should have been a copy of the tech sheet, the same or similar to the one Denman referenced.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/eab852a13fbc842085256aa200643dd6/$FILE/Duet%20Job%20Aid.pdf[/quote]
Thanks for the manual-Another free repair service said press the end of cycle button for 3 seconds and it should unlock,and it did.
Great, thanks for the update.
thanks for the info. the press “end of cycle” worked for me this time.![]()
