Control panel board completely dead - NO display
Brand: Maytag
Model Number: MER5555RCW
Main Symptom: control board panel NO display (so oven = no worky)
What happens & when: stove top elements work, bake element about 16 ohms, broil element about 14 ohms, cant find HI LIMIT SWITCH as shown on schematic (i think there is a hole for it but it doesnt exist - that i can find). i can do board level repair… oven temp sensor measures about 1050 ohms. (cold) Would like to know IF this part is inductor OR resistor - it is marked as 180k, its black, cylindrical, and measures short circuit using meter. in the photo link the component is in the lower left corner of tan PCB. i cant see and voltage regulators but somewhere i must be able to measure 24VDC (for relays use that)
Parts or tests already tried: measured power 120 VAC getting to the control board on pins 1 & 7 of white PCB connector
Photos / video link:Whirlpool WP5701M717-60 Range Electronic Oven Control Board And Overlay Kit | Genuine OEM Part
Unfortunately, the manufacturer does not identify if the component is an inductor or a resistor as it is considered proprietary information. With this being the case, we would only be able to suggest replacing the control when a soldered component has failed. Whirlpool WP5701M717-60 Range Electronic Oven Control Board And Overlay Kit | Genuine OEM Part
i am able (and did) to do board level repair (and wanted to avoid the $500-$600 CAD panel replace part charge) long story short – i replaced all 7 capacitors, and she WORKED !) Total cost for parts about 8 bucks…
