The control panel went blank and the handle had no tension with the door closed. I opened the door and the handle was broken, I replaced the handle but there is still nothing happening on the control panel. I checked power going into the latch assembly and it was there. I had power going to the latch assembly from the black wires and power going through the switch until I connected th pinkish wires going into the other side of the latch assembly, then I only had power on the black side. Bad latch assembly??? Thanks in advance!!!![]()
With looking at your wiring diagram, the pink wire goes from the control board to the turbidity sensor, not to the door latch.
Nat
