Control Lock will not clear
The control lock is the only light that will come on the unit. I could hold down the energy save/dry button but this would not clear it. If you hold it for about six seconds the light went out and the Rinse Only light would flash. When you released the button the Rinse Only light would go back off and the control lock would come back on. No other light will come on. I removed the panel and looked it over. pulled the ribbon cable and pluged it back in and now it is clear. The only buttons that light up and seem to work is the option buttons the rest is still dead.
What should I replace first?
Hi Hagarr,
Most likely the problem is stuck one or more pads on the key panel.
The correction is to replace the control panel. In order to provide the right part number I need the color of the control panel.
Color of unit is black.
The part number for the control panel is [COLOR=#0066cc]AP3174692[/COLOR]
Here are the break down diagrams for the Kitchen Aid dishwasher Model KUDS01DJBL0
I got the part this afternoon and had the part installed within 15 minutes.
Unit is working great!
Thanks You for the help and the great price.
Hagarr
