Control board will not output power to water valves
Brand: MAYTAG
Model Number: MVWB835DW4
Main Symptom: No power output to water valves from mother board
What happens & when: Washer locks the lid, washer goes to sensing mode, washer spends 3 minutes sensing, washer lights done. No Error code, no power output to valves from control board
if you are certain there is no voltage going to the valve, the control board would be the problem being that it is what sends voltage to the valve. W11400681 Electronic Control Board | Genuine Whirlpool OEM In Stock
