Trying to get my oven back working. Reset everything, breaker, etc no burnt wires but still not working. Control board clicks and broiler and oven elements both don’t work.
Model # LFEF3011LBD
Part # 316455500 Rev E
I can’t find this control panel anywhere.
I’m sure there are parts that are compatible but I go down so many rabbit holes trying to find it. Please help.
The model number shows this part as your clock and you may need to get the overlay if your old one is damaged or if you tear it while removing it from the old clock. ( clock = computer or ecu to some companies )
https://www.appliancepartspros.com/frigidaire-clock-es100-5304518660-ap6892696.html
https://www.appliancepartspros.com/frigidaire-overlay-316220725-ap4557156.html
Ok awesome! So these parts will work for my stove? And do I just get the new piece and plug all the wires back the way they were originally?
