I have replaced my control board in my double oven because the touch panel was not working (thunder storm did it again).
After installation and powering up the unit it is asking to set up the unit. I do not have a clue of what to put in. Is there a service manual for the unit that tells me how to do it? If so I would like to purchase it.
when replacing the control board, the board has to be told what oven it is in.
it needs to know if it is a g.e. profile, or a g.e. monogram.
here are instructions
power oven off.
power oven back on.
within 5 mins of powering up, press 0803
press factory 1 on display
press change until it displays proper name
press accept, to confirm
press exit.
you should be able to say “presto”
scott
