received control panel part; washer flashing & not working, just over 1 year old; replacement control panel looks wrong–where is the circuit board panel? mine only came with the outer cover face and a plug; no circuit board as I see on old washer? what gives? is it supposed to come with circuit board too? thanks
I cannot find any info on the given model number.
Tried AppliancePartsPros and the Whirlpool sites.
Please check it.
Also what are the part number/s that you ordered.
part sent me was Whirlpool W10250016; it was recommended & ordered during a live chat I had with technician after I checked & gave the washer model #; any help would be appreciated–thanks
model # i’m reading is right off the warranty card—KUDS30IVWH4;
Here are your parts.
I could not find a VWH4 so the following is a VWH3 they are probably the same.
Replacement parts for WHIRLPOOL KUDS30IVWH3 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
W10250016 is the Panel Ctrl (control panel).
It should be basically the keyboard.
The hosing with the keyboard installed and a ribbon cable coming out of the keyboard which plugs into the control board.
If you want the Control Board then it is AP4564002.
f21 is the code on my washer want drain hose noy kinked or stoped up i dont know what part to get help
ok–thanks–
how does one tell what part is bad? i guess plug & play will tell, right? do you buy both panel & keyboard to be safe? first time with your guidance- existing one looks like keyboard plugs in back of control board & board looks semi-fixed in place withbracket-like tabs; does not look like a simple snap-in removable setup; any hints? thanks! (getting close to holiday dishes and panicking)
[quote=denman;592870]Here are your parts.
If you want the Control Board then it is AP4564002.[/quote]
[COLOR=“DarkRed”]how does one tell what part is bad? i guess plug & play will tell, right?[/COLOR]
The usual way to troubleshoot theses parts is to disconnect the keypad (panel) from the control board and then check the keys at the ribbon cable with a meter. If it checks out OK then replace the control board first.
Still a bit of a crap shoot but your odds are better.
Sometimes the following works for bad keys or no keys.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
I have been trying to upload the tech sheet to you but it fails. Could be a problem with this site, I will try again later today.
In any case it is usually taped to the back of the kick plate.
Sorry I do not follow the second part of your post.
On many units the board just snaps onto the front panel. Some units also have screw/s. If it is snapped on just be gentle as yuou do not want to break the snaps.
Well I have been able to attach files to other posts but cannot add an attachment to yours.
have tried several times with different file downloads without success.
So hopefully the tech sheet is under the unit.
thanks for the time & info, denman–really appreciate it; feeling a little better with your info & with a forum out there to help; we will give it a try; pre-holiday panic and local fix guy wants lots of $$$ just to visit; sometimes think the old mechanical switches on things were less hassle; thanks again! oh–what about stuff like Noalox (joint compound for electrical?) to put in wire plugs to keep out moisture? advised? thanks–
I would not put anything on the contacts.
These are meant for places where there is a high pressure contact between the male and female conductors like a screwed on connection.
thanks for your help & patience; will not put goo on plugs; if things can not get posted here, likely my antivirus stuff; but–learning a ton as I go along–thanks
this has been really helpful !
looks like the touch pad panel replacement worked; must have been only the touch pad buttons; ran a few cycles to date & o.k.; not too hard to replace either; i figured out how to unsnap the door lock and circuit board components; Thanks to Denman!![]()
