Control Board problem?
Brand:GE
Model Number:JS760SL1SS
Main Symptom:Temperature continues to rise in bake
What happens & when:convection bake works bake doesn’t
Could you describe what is going on a little more? Is this only happening with regular bake? Does it happen in broil? When you say the temperature keeps rising, does the temperature on the display keep going up or is it just the actual temperature in the oven?
broil and convection bake work. The actual temperature in oven goes up
Good deal, that’s going to be an issue with the main control board WB27X33138 since broil and convection bake work properly but regular bake doesn’t.
tried to take control board out but the connections are so tight can’t pull out. Is this the way they are or is their a certain way they come apart. a video would be helpful. If i could get it apart I would buy a new board.
If the wires on the relays are the ones being difficult that’s pretty much how they are, easiest way is to work them back and forth while pulling on the connector. The rest of them should have small clips that need to be depressed, but they can still be a pain to get out, same process, just rock them back and forth with the clip depressed.
