Control board does not match original. support says it is the correct part
Brand:Samsung
Model Number:RSG257AARS/XAA rev 01
Main Symptom:will not reset after loss of power
What happens & when:after power loss displays88 88. Will not reset.
Parts or tests already tried: Ordered new control board. Does not work. New board I also checked, and DA41-00522A is the correct control board for your model RSG257AARS/XAA Rev. 01.
The replacement board has a different pushbutton spring design, Open at top. Original had a wire cap to make contact with center pin when pushed. The design difference does not work. Is there an updated version or if there’s another issue
How does that one look ( Samsung DA41-00524A Refrigerator Pba Main | Genuine OEM Part )
No old part was DA41-00522. New part DA-00522A seems to require button ‘grommet’ to work. I have grommet on order to try.
