Control board connectors
I received a new control board for the dishwasher. The electrical connectors on the old board are parallel but the new board has them at a right angle placement. I confirmed that the new board is current replacement. Should I just rotate the connector block to make sure that the colored wires match the color codes on the new board, ie gray wire to GY post, blue to BU and white with red stripe to W-R? They will align properly and make a proper connection. thanks
Duplicate post.
