Control Board bought from your company
Brand: Frigidair
Model Number:FGHD2465F1A
Main Symptom: Won’t power on
What happens & when:When you open door control panel light’s up and you can select any function. When you close the door the lights stay on for about 20 sec and go out. As long as the door is closed, none of the control panel buttons will work. I have also been able to cycle thru the delay timer to be sure it’s not in a delay mode with the door open. This is what happens with the control board sent to me from Appliance Pros. Also, the package was opened and resealed before it was shipped to me. My original control panel was causing the dishwasher not to stop at the end of a cycle (any cycle) I selected. I could run the machine through any cycle I selected; it just would not shut off after the display timed out for that cycle.
Sounds like you may have gotten a faulty control board that is causing this issue and would suggest requesting a replacement.
