Connecting a hard-wired stove to a power cord
I have an old hard-wired stove I was given that works. I would like to put it into a rental I have. The rental has a 3-prong outlet. I was wondering if there is any way to connect a power cord to the stove to make it usable.
Thanks!
Yes you should be able to buy and install a 3 wire line cord for it.
Important things to note are:
  1. Make sure to install a strain relief where the cord enters the unit. This ensures that the cord cannot be pulled off the connectors and that the sharp metal will not cut/short the power cord.
  2. If the unit was hooked up to a 4 wire a grounding strap has to be wired in from Neutral to the unit’s frame. Check and make sure that grounding strap is installed
  3. If it is an inline terminal strip in the unit Neutral (White) is normally the center connection. L1 (Black) and L2 (Red) are usually the outside 2.
  4. If not confident that you know what you are doing, get a pro in to hook it up.
This may also help.
http://www.applianceaid.com/erange.html
