Symptoms: No cooling at all in freezer or refrigeration section. All interior and exterior fans/lights/etc work fine, but internal temp is at a nice warm 72F. The compressor hums for a few seconds, then shuts off with a soft click, then repeats after a few minutes. The top of compressor is very warm/hot after this goes on a few hours.
This has happened about five times since last summer. Generally, the fridge starts working again after anywhere from 1 day, 1 week, or 1 month (I once left it on for 2 weeks, gave up and turned it off for a month, turned it back on, then it started working after 1-2 days). I was working 7 days, up to 85 hrs/week at the time, so I really didn’t need a working fridge.
I actually never noticed the compressor not running before this latest incident. It could be that it wasn’t running the other times and I mistook the fan noise for the compressor. Or it could be a new wrinkle.
Anyway, after reading a LOT of posts, it looks like the problem with the compressor not running is most likely either the relay, capacitor, compressor, or some combination of the three.
Capacitor:
I tried checking the resistance of the capacitor. I read some resistance value for less than a second, then the meter reads no continuity and stays that way (I stopped after about 10 seconds). Does this mean I’ve got a bad capacitor, or am I doing something wrong with how I’m taking the measurement?
Compressor:
I checked the resistance between compressor pins and from pin to ground. Got a very low resistance (almost zero, I think) between pins and no continuity from pins to ground. So, is it safe to assume the compressor is good?
Relay:
The wires are recessed into the relay housing, so they rattle against the housing, which means I can’t tell if something else is rattling. Is there some other way to test the relay? Better yet, how do I pull the wires out of the relay housing?
Is there anything else I should be checking?
Any advice would be greatly appreciated.
