Colthes to wet after spin cycle
Brand:GE
Model Number:GTW330ASK2WW
Main Symptom:clothes do not seem as dry after spin as when machine was new
What happens & when ran spin test with latch overridden, lid open, empty basket, adgitater wobbled alot when the highest speed came on. Test ran all the way an shut down O.K. Pushed down on basket and it only bounced once.
Error Code (if any): Error 26
• Redistribute the clothes: Open the lid or door and spread the clothes evenly around the basket. Mix heavy items (like towels or comforters) with lighter clothes. Remove items if the machine is overloaded.
• Level the washer: Check if the machine sits flat using a spirit level. Adjust the leveling legs until the washer stops wobbling.
• Perform a hard reset: Unplug the washer from the wall for about 5 minutes to clear minor electronic glitches.
If balancing the load and leveling the machine do not clear the code, the problem may be hardware-related:
• Check for obstructions: Manually spin the empty basket. Grinding noises or resistance mean an item is stuck in the tub, or the spin bearings have failed.
• Inspect suspension and parts: Worn suspension rods in top-loaders or a faulty gearcase/inverter board can trigger recurring 26 codes.
