Morning.
We have a stackable which had worked great for the last two years and now for some reason the cold water stopped working and the hot took its place…we did all the things everyone recommend, from cleaning out the hoses and then the filters. Eventually we just switched the hoses and used cold for everything.
Last week a friend borrowed the washer and I forgot to mention the issue so she moved the knob to hot and now the water is back to its regular system…problem is we moved the hoses so now its hot water on the cold and hot water on all the cold rinses…
Before we go back and switch the hoses again, I’d like to fix the problem, but not sure on these how to go about troubleshooting (and where! none of the manuals I’ve found show it) either the temperature control switch or if its the actual knob on the front panel or if that is the same thing.
Any direction would be great…we’re pretty handy and can tackle a lot of things but I’d prefer to know some or have a manual to follow before we start taking this baby apart…
[quote=SardiHome;576618]Morning.
:D[/quote]
Hi. We will need the exact model # to assist you further with correct part numbers. Thank You.
[quote=SardiHome;576843]I apologize…
do you know where on the machine we would find the model number? I’ve found a number of metal stamps but none of them say model number~[/quote]
Hi. The model # on a stack laundry is put inside the dryer door area. Inside on the inner front panel or on the inner door panel itself. Good luck, Thank You.
[quote=SardiHome;579955]Thank you, it only says MOD so hope that is correct.
WET 3300SQ1
:)[/quote]
Hi. You will need to replace the temperature control AP6237529.
The water valve has a thermistor which senses incomming water temperature so the control will allow the water valve to mix in automatic temperature control wash.
Water valve AP6009051. Thank You.
[quote=Ted/APP Team;579974]Hi. You will need to replace the temperature control AP6237529.
Water valve AP6009051. Thank You.[/quote]
HI Sardihome. The temperature control can be accessed from behind the control panel. Remove power. Remove console end caps. Remove knob.Then you will be able to lift the control panel assy. up and off the whole assy. off the rear frame. There is a lift/locking tab on the back of the switch body thet you lift out of a hole.Then twist slightly and pull out from the back of the panel. Remove and replace the wiring connector.
For R & R the water valve;
Then you need to remove the top. Approx. 3 " in from each front corner are locks. You use a putty knife from the front and push in the center of the clip and lift each top corner up. Then you will be able to pull fwd. on the top and lift up. This will give access to the inner lid switch connector. Unhook this from the control panel. Then lay the top assy. to the side. Then remove the front panel by removing 2-1/4" screws from the inside of the front panel. These screws will be approx. 1’ down in from the top. After these screws are removed, you will be able to lift up on the front panel off the 2-inner lt. and Rt. clips. Set the front panel aside. Unhook the wires to the water valve. Take note or picture of the water valve wires first. Then remove outer supply hot / cold hose’s. Remove the water valve to tub hose (air flume hose). In the middle of the water valve is a 1/4" mount screw, remove this. Then you lift the water valve up and pull out from the inside of the cabinet. Reassemble in reverse. Thank You.
