I can turn fridge off or on with cold control but sometime will not turn off automatically even when cold. Will replacing cold control thermostat (your part # AP 4084658 ) fix the problem?
Thanks :Bob
As long as you are sure that the freezer and fresh food sections are getting down to the set point temperatures then replacing the control thermostat should fix it.
