Coils Inside Bottom Mount Freezer Freezing Up
How To Test Parts That Would Cause The Coils To Freeze Up In The Bottom Mount Freezer Of My Refridgerator. Gb22dkxgb02
Replacement parts for WHIRLPOOL GB22DKXGB02 | AppliancePartsPros.com
See the attachment for the tech sheet. I could not find one for a GB02 so it is for a GB00
I would also check the door seals but it does sound like a defrost problem.
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle by turning the defrost timer cam (Item 38 in Section 6) till the fans and compressor turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it’s rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 10 in Section 6) from the wiring and measure it for continuity, usually around 30 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (Item 14 in Section 6) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
GB22DKXG.pdf (97.6 KB)
