Code OE
:confused: Yesterday I wash washing a blanket and the code OE came on and it stopped running. What does this code mean cannot locate my book. Thanks, Carol
What brand is your washer?
:confused: the brand of washer with the code OE error is an LG TROMM.
Thanks, Carol
The manual states the following about the OE Code:
Problem Cause:
Drain hose is bent or clogged
The drain filter is clogged
Solution:
Clean and straighten the drain hose.
Clean the drain filter.
Hope this helps.
