code E48
I have a frigidaire affinity front load washer when u start cycle pumps in water in for about 5 seconds then shuts water off and just sits idle counting down the timer.It has a code e48 any help would be greatful!!! also I unplugged it for a minute or so and then cycled it again it started to work until it went to agitate it did agitate a few times then quit!!
Take off the bottom service panel and you should find some tech notes. They will tell you how to interpret the error code and how to test components. Focus on the door lock assembly, and also the main and speed control units.
The other day I ran it on spin only just to see what it would do. The only thing that ran was the pump and the clock it didn’t spin after the cycle was finished I checked the codes again this time it had E57 any ideas?
Try to do some of the tests in the tech notes and see what you can determine from those results.
