The clutch on my GE washer slips so I’m planning on replacing it. I’m looking for help on completing the repair. It appears that I have to remove the drive belt and then pull the clutch off of the motor. I’ve been fooled by other “easy” repairs so I’m looking for advice or any tricks that will ease the repair. Thank you.
Slip off belt, remove the 4 3/8 nuts holding motor, remove motor,.remove clip off motor shaft that holds clutch on, remove clutch, (Sometimes you need a small gear puller) assemble in reverse order
Thank you. This is indeed an easy repair.
