Clutch and agitator replaced, still doesn't spin full speed
It doesn’t seem to spin full speed still after replacing those parts.
Brand: maytag
Model Number: MVWC565FW0
Main Symptom: not spinning full speed . Clothes still very wet
What happens & when: spin
Photos / video link: https://drive.google.com/file/d/14y96O83iGFbmM61hVjDJHF_WjorVtOTj/view?usp=drivesdk
Have you removed the basket? That acts like there is something loose in the basket area.
I only replaced the agitator. I only removed that little piece. Is there a video for that and what should I be looking for? Just broken parts?
When I pulled the agitator hub drive off, the piece in the middle with the splines that feeds into it wasn’t attached to anything.
I pulled it out and inserted it into the hub.
I looked at the piece and it didnt seem to be snapped metal. I was thinking that it had to attach to something but I figured that once I put that center piece back, the rod on the center piece would feed through and hold it together.
